Hey Tim,
I'm not hammering on you here.
I didn't know it was possible to install the pressure plate backwards.
Are you sure you don't mean the clutch friction disc?
transmission install woes
- RoyBatty
Re: transmission install woes
Yes, the one thing that could possibly go backwards was unmarked except for a green dot. Whatever you call that flat plate with the springs. That was backwards.
all of that is good now. Now sorting through electrical/dizzy issues.
been a very long year of this stuff
yes, the clutch plate can be put in backward. As I recall, the springs and the spines stick out farther on one side than the other. Don't know how much difference it makes.
