Here's a bit of a problem. After successfully installing a
new intake boot to repair an air leak, I wanted to set my idle properly. My spider was idling around 500 rpm which is low for a 5spd. Using Brad's guide I fully set the idle screw, but when I went to tighten the accelerator stop screw to raise the idle, I found that either the screw or its housing is partially stripped. The bottom 1/4 inch will screw will hold against the spring pressure of the throttle, but beyond that, the throttle will push the screw straight through the threads.
This photo is my best effort at illustrating my problem. I had tightened the screw to the point where the lock nut was flush with the housing, but when the throttle pressed against the screw it "popped" back to this position.
I'm hoping that it is the screw that is bad and not the housing, because that seems like much less of a hassle. Does anyone have a good suggestion on where to source a replacement screw? Any thoughts on what I should do if it's the threads on the housing that are bad?
