Washer Bottle Fix???
wizard124
Post by wizard124 »
Quick question. Does anyone have a proven fix to replacing the pump on an '80 FI or later car :?:
This is my story. Mine was missing. I purchased bottle with pump from a salvage yard. At the time, he hooked it to a battery and the pump worked :)
I installed it much later (after the paint job). It squirted but also leaked badly. :x I pulled the bottle to take a good look at it. The leak is between the base and the motor. The base to the bottle is tight and not a problem.
I've drilled out the rivets and separated the motor. The motor had corrosion internally; meaning it had a water leak through the shaft. It has been cleaned and lubed and is working again.
To fix this shaft leak, I added an 0-ring and siliconed it to the larger original rubber seal. Because this original seal leaked, I added silicone. Put it back together,,again,, and again,,and again :twisted:
I surmise that the motor just isn't strong any more. While it spins freely without the rubber seal, it bogs down and stops when it has to spin through the rubber seal.
I have given up trying to make it work (something so simple :? )
The pump is fixed to the bottle with an internal retainer ring. Once it comes off, it is off for good. One option is to buy a pump from a vendor (it appears to be the same motor) and attach the new motor to the old base. I might end up with the same leak. If it is the same motor, it is none too reliable judging from the posts I have read.
This leads me to my original question :?: Does any body know of a proven replacement pump?
divace73
Re: Washer Bottle Fix???
Post by divace73 »
I had an issue where somehow my motor went missing (in my own shed??) while my car was getting painted, I took the bottle into a auto store and from memory a Ford pump fit straight in and worked a treat (the connector was a little different) however I have noticed that on other 1980 FI cars that the pump is external??
My be wise to go to a knowledgeable (I know they are rare now) and ask if they have anything that fits in, I had to make sure I didn't mention Fiat here as they would automatically result in a NO.
Cheers David
see my >>You tube channel<<
I installed this one into the water bottle on my 81. Works fine. I had to open the hole in the bottle slightly for the new seal.
http://www.autozone.com/electrical-and- ... _193814_0/
wizard124
Post by wizard124 »
[quote="spider2081"]I installed this one into the water bottle on my 81. Works fine. I had to open the hole in the bottle slightly for the new seal.
http://www.autozone.com/electrical-and- ... _193814_0/[/quote]
Perfect! Just the info I was after
