Tie Rods
Re: Tie Rods
you are looking for a pickle fork. search for it and you will see various versions of it on line. Harbor freight has a few types.
The ball joint separator looks like it would be difficult to use in tight places.
Re: Tie Rods
I like this tool from Harbor Freight
http://www.harborfreight.com/3-4-quarte ... 99849.html
I tighten it up till there is a good tension on it and then hit the end of the tool with a hammer.
Re: Tie Rods
I may also suggest a BFH
Re: Tie Rods
It's hard to do this without ripping the boots from the friction of the pickle fork. Try lubing the fork with silicone grease. You can buy new boots separate from new tie rod ends.
MikeR
MikeR
