normal heat range
normal heat range
78 fiat 124--any one know normal heat range--mine runs around 125 before the fan comes on
Re: normal heat range
if you are talking centigrade then it is too high, if you are talking farenheit then it is too low
My understanding is that it should engage between 190*F-195*F
There are lower temp components that can be used
- bradartigue
The point of engagement for the fan should be on the "0" of the "190" and the point of disengagement is straight up and down, vertically oriented on the "9". It is common for the fan to run continuously when stopped on a warm day - and when doing so it should keep the needle on the "9".
1970 124 Spider
http://www.artigue.com/fiat
I think I fixed it --seen a post about massaging the water hoses to get all the air out. Even though it was not that much, it worked --holding 190 now----I learned a lot from this site
Re: overheating
1978 spider 124- running hot around 225--changed both the thermostat and radiator sending switch--the fan will still not come on--however the fan works when I short it out so that is not the problem---does the two temp sending unit in the valley have anything thing to do with it and are they both the same when I want to change them out
your temp switch in the bottom of the radiator can either be bad or the bottom of your radiator is still too cold. An infrared thermometer would tell you. The sensors in the head are not the same. One runs the gage and the other the idiot light.
you are right--I used the infrared on the outside of the switch and it showed around 180 while the temp gauge in dash states 225--do not know why the heat is not getting to the radiator switch area
Re: overheating
This might helpbsharp wrote:1978 spider 124- running hot around 225--changed both the thermostat and radiator sending switch--the fan will still not come on--however the fan works when I short it out so that is not the problem---does the two temp sending unit in the valley have anything thing to do with it and are they both the same when I want to change them out
http://www.international-auto.com/videos.cfm
