Removing rear shocks
fiat218
Re: Removing rear shocks
Post by fiat218 »
4uall wrote:Thanks to all of you
Bought Fiona some new KYB Excel - G's for the rear
Use a 14mm to loosen top nut on rear shocks
Be sure to stuff a rag in the pit of despair
Remove drivers side pan hard rod 24 mm nut
Jack up one side to lower the other
Spring and shock removed
New shock installed and spring easily seated
1 knuckle bleeder out of 10
Clean your finger nails. Geesh
4uall
Post by 4uall »
stop looking at dirty pictures of guys hands ya perv :roll:
fiat218
Post by fiat218 »
4uall wrote:stop looking at dirty pictures of guys hands ya perv :roll:
:mrgreen: sorry
srwilson
Your car is a: 1979 124 Fiat Spider 2000
Post by srwilson »
I finally got around to replacing my rear shocks today. And a big thank you for the post and tips! I'm sure it went a lot faster and with a lot less cussin' because of your help!
-Steve
1979 Black Fiat Spider
2006 Black Chevy Silverado Crew Cab
wetminkey
Post by wetminkey »
Nice picture tutorial, Jay! It will make this job easy when it comes time for me to replace the rears.
Thanks, again.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
4uall
Post by 4uall »
Thanks Todd :oops:
I am a visual learner myself and I always appreciate when someone would show me step by step with pics, so I like to do the same :wink:
wetminkey
Post by wetminkey »
I have done a couple of picture tutorials on other forums, and they are a magnificent way for us to present "how to" information to others. Build threads with pictures are also very good, but do not organize the information as well.
Please keep up the great work! I'll try to add some of my own picture tutorials as I get to different projects too,...I've got a pair of great cameras for that kind of work.
Todd,...again!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
jimmycakes401
Post by jimmycakes401 »
I'm hoping to do mine this summer at some point if other things don't keep getting in the way. Great guide to replacing the rear shocks. Might have to pull out all my stuff and paint it while I'm in there. I like that idea. Do the shocks come with all the rubber or does that need to be ordered separately? Anyone recommend replacing any other pieces while in there? I assume the caps don't come in and out.
4uall
Post by 4uall »
My understanding is that all the pieces (rubber included) come with the shocks :wink:
jimmycakes401
4uall, you say jack drivers side to lower passenger. At that point, which do you unbolt? I assume the driver since it is compressed? Then you lower it and remove the shock. Is this correct or do I have it backwards.
Second question: d
4uall, did you remove the brake line?
4uall
Post by 4uall »
i did it a different way :| the side that is raised lowers the opposite side, i remove the lower side then switch
think of a seesaw, /
your way would work however, possible danger with compressed spring :shock:
i did not remove the brake line either time, guess i got lucky :oops:
jimmycakes401
Nice! Your jack stand is in the standard jack spot right? Looking forward to replacing these.
jimmycakes401
All done. Very easy. But I need to tighten my panhard bolt. Anyone know the torque spec on that? Does it matter?
4uall
Post by 4uall »
I just really tightened it :shock: :oops:
jimmycakes401
As did I. Will test drive later.
