Hi,
I have just about lost it with burning out the contact points in my '77 124 and have started investigating electronic ignition systems. I am not looking for any performance boost, just increased reliability. Has anyone ever done this or know of any companies that offer a decent system?
Thanks.
Alex
Electronic Ignition
Re: Electronic Ignition
Thanks Mark.
Is there a Marelli system designed for a later FIAT that I should look for, or did they specifically make an aftermarket unit?
I have also heard a bunch about Pertronix. Any opinions on those?
Alex
Alex
Marelli elec units were stock from 79 on. I haven't used Pertronix
- bradartigue
You can use the entire ignition system from the 1979-1985 Spider 2000. It works "out of the box" with no points to adjust. FWIW Marelli sold a replacement unit called a Marelliplex, which is identical to the 79-85 unit but doesn't require vacuum advance to operate. The plex can be had for about $800.00 from one vendor and almost never found used.
If you use the original unit from a Spider 2000 then use a carburetor that has vacuum advance, otherwise your low end performance will suffer.
1970 124 Spider
http://www.artigue.com/fiat
- perthling
- Your car is a: 1974 124 Spider
I'm just converting my '74 across to a later 131 electronic ignition setup. Can I stick with the original coil or should I upgrade, and if so, to what? I have read much conflicting information on whether the coil should be replaced.
Regards
Regards
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
Perthling
I'd convert if for no other reason than to get a higher output. Those e-coils put out twice the voltage your oil filled unit produces
