Removal of old and installation of new radiator RESOLVED
4uall
Re: Removal of old and installation of new radiator
Post by 4uall »
Tell your wife "you're welcome" I was throwing candy out to the kids along the parade route :mrgreen:
Next time, introduce yourself :wink:
4uall
Post by 4uall »
Hoping to complete this weekend, photos to follow as always :wink:
Online
I just replaced the radiator in my 81 spider. I removed the air filter box as suggested here and the coolant "T". I think the added working room with them removed is worth the time. I also used new coolant as the existing was over 5 years old. I have the plastic "T" in the heater line but filled the system per the instruction sheet you have. After the car cooled down I topped off from the "T" in the heater line. All seems good.
4uall
Post by 4uall »
8) i may need some help this weekend if i run into any problems
4uall
Post by 4uall »
Almost two years ago to the day I received my new rad from autoricambi 8)
Spent some time this afternoon doing an oil change, new rad install and new hoses :mrgreen:
Perfect fit with zero adjustments needed :wink: Thanks Autoricambi
Filled on level ground, half filled the overflow, left the cap off, ran the car three fan cycles beautiful :mrgreen:
That
Re: Removal of old and installation of new radiator RESOLVED
Post by That »
I'm gonna remove existing radiator (damaged lower tank) and replace with another similar radiator. Any tips or tricks to this job? I am a 77 yr old fart with a few hand tools.and a 1982 fiat spider that I dearly love! Does elec fan come out with radiator, or have to remove fan first? Any help will be appreciated.
4uall
Post by 4uall »
pretty simple :wink:
drain rad fluid
unplug electrical connection to rad fan
remove hoses
remove three nuts that hold the fan
remove rad
repeat in reverse
That
Post by That »
Wow! Can't believe it's so simple. Remove fan first or leave it attached? Thanks
Pulling the rad is one of the things that is actually pretty easy on these cars!
