I have a service manual, I have been told that the torque spec for the water pump bolts is incorrect. The manual states they should the torqued to 17lbs. I know when I went to install the water pump to that torque it easily snapped a bolt and would have snapped all 4 if I had kept going.
Can anyone please let me know if this torque is correct or too high. Separately, if anyone knows of a place that has all the torque specs for the engine that would be a great quick reference for any work.
Germ
Torque specs
Re: Torque specs
14 lbs to 15 lbs seems to be correct
http://www.fiatspider.com/f08/viewtopic.php?f=5&t=20749
these are for 2000 & 2000 turbo
http://www.google.ca/url?sa=t&rct=j&q=& ... 7471,d.aWw
Google is your friend
Re: Torque specs
Sorry, forgot to add that I need the specs for a 72 1608 motor/water pump
OnlineKidDingo
- Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Re: Torque specs
Try this library of manuals and service docs set up by Nate:124Germ wrote:Sorry, forgot to add that I need the specs for a 72 1608 motor/water pump
https://drive.google.com/folderview?id= ... sp=sharing
_______________________________________________
Michael
Michael
Re: Torque specs
KidDingo wrote:Try this library of manuals and service docs set up by Nate:124Germ wrote:Sorry, forgot to add that I need the specs for a 72 1608 motor/water pump
Thanks, but the link didn't work.....404 error.
OnlineKidDingo
Re: Torque specs
Apologies. Try this: https://drive.google.com/folderview?id= ... sp=sharing
Michael
Michael
