Thought I'd share what I learned when I installed a voltmeter this past weekend. I figured it might save someone else a load of time in researching it, and make it easy to just follow a series of quick instructions.
My '81 FI has had some battery issues, so I wanted to keep an eye on the charging system. I wanted to watch the voltage out of the alternator. I found that fuse N, which is reserved for a power window motor (which my car doesn't have), had a spare connector.
Just in front of the fuse panel, under the dash, is a bolt holding a triangular bracket against a brace that runs across the bottom of the dash. It's an 8mm bolt and it will fit perfectly through one of the holes on a voltmeter bracket. It also acts as a perfect ground. In order to see the voltmeter gauge, I had to spin it so it was upside-down in the bracket and then bend the bracket so it faced upwards.
1. Connect the positive connector on the voltmeter to the chosen fuse (in my case, this was fuse N)
2. Connect the voltmeter negative terminal to the grounding bolt - the same bolt holding the bracket in place
3. Bolt in the voltmeter
You might find it easier to cut a slot in the bracket hole and slide it under the loosened bolt head. Taking the bolt out completely is a bit rough because it's a real bugger to get back in - not a lot of room to get your hand in behind to tighten the nut.
If you want to read the voltmeter in the dark, you'll need to install a light bulb and wire it to the headlight switch circuit. I didn't bother with this because I don't do a lot of night driving, if any at all.
Turn the ignition switch to the 'on' position to light the dashboard lights. The voltmeter should show the battery voltage. Run the engine and the voltmeter will show the alternator voltage. This will probably differ depending on which fuse you use.
What I like about this installation is that it's a permanent temporary solution. In other words, it doesn't affect the dashboard layout, so if you're keen on keeping it all original, you can easily pull out the voltmeter without any scarring or ill effects on the condition of the car's interior.
None of this is earth-shattering news, but if it saves someone a few minutes of mucking about, then all is well.
Voltmeter installation
OnlineKidDingo
- Your car is a: 1981 Fiat Spider 2000 FI 5-spd
_______________________________________________
Michael
Michael
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
Re: Voltmeter installation
michael - what brand voltmeter did you install? does it have a spot for a bulb (like our gauges do)?
1975 Fiat 124 Spider
OnlineKidDingo
I got it from Princess Auto, Canada's rough equivalent to your Harborfreight, I believe.btoran wrote:michael - what brand voltmeter did you install? does it have a spot for a bulb (like our gauges do)?
The brand name of the voltmeter I bought is Princess Auto's inhouse brand called (heh heh) Power Fist - I kid you not.
It has a hole for a bulb but did not include the bulb holder in the package.
Michael
Michael
