I see this is a common issue. I was wondering if someone had any pics of how they fixed it? Just looking for some ideas. I am going to fix it myself. I have seen a couple posts, but nothing with the final fix.
Thanks.
'77 firewall cracked from clutch
- Rupesy
- Your car is a: 1977 Spider
'77 Fiat Spider
'79 Porsche 928
'83 Jeep CJ7
'04 Chevy Suburban
'04 BMW Z4
'00 Porsche Boxster
'79 Porsche 928
'83 Jeep CJ7
'04 Chevy Suburban
'04 BMW Z4
'00 Porsche Boxster
Re: '77 firewall cracked from clutch
I drilled a hole in an old motorcycle tire iron, and siliconed it to the firewall.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Take the brake booster and MC out/off.
I had a parts car and cut the same piece from the fire wall. A piece of sheet steel a couple of mm thick with the hole cut out would work. I then pop riveted it into position over the straightened cracked fire wall. Then with a WET rag below and on the inside, I welded the covering piece to the fire wall.
Worked great. took about 3-4 hours to do.
Chris
Chris
- divace73
I'd like to see that.bobplyler wrote:I drilled a hole in an old motorcycle tire iron, and siliconed it to the firewall.
Cheers David
see my >>You tube channel<<
I since had it repaired correctly. That was about 20 years ago. And I had no other car at the time, so had to improvise one night.divace73 wrote:I'd like to see that.bobplyler wrote:I drilled a hole in an old motorcycle tire iron, and siliconed it to the firewall.
If you are concerned about heat damage, you may want to epoxy the new plate to the firewall.
bobplyler wrote:I since had it repaired correctly. That was about 20 years ago. And I had no other car at the time, so had to improvise one night.divace73 wrote:I'd like to see that.bobplyler wrote:I drilled a hole in an old motorcycle tire iron, and siliconed it to the firewall.
How's it go?
Ingenuity is the mother of all invention!!
I think it's, "Necessity is the Mother of all invention."
Fred
Lake Norman, NC
1977 Fiat Spider (current project)
1977 Triumph Bonneville 750 (previous project)
1971 Honda CT-70 K0
1972 Honda CT-70 K1
1990 GMC S-15 Jimmy (Daily driver)
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
