Newbie goes for the Front end
Re: Newbie goes for the Front end
Jack up A arm to compress spring. Now get some bailing wire or a bunch of zip strips-wire ties to hold spring compressed a bit. Now let jack down. Spring will be somewhat compressed and come right out.
There's a tremendous amount of energy stored in a compressed auto spring. Can be a very dangerous item. Don't screw around with it, get a spring compressor, imho. Especially if you are a "newbie" (like me).
I agree with Roller. I have done this operation several time including twice in the last 6 months. I have spent alot of time around machinery and know what i am doing. As stated, there is a lot of force in that coiled up spring. This is a dangerous spot for a newbie. Be safe and get a spring compressor. your fingers will thank you.
Yea I just got through with a front end job on mine. Decided to break out the old engineering text books afterwards. Potential energy in a spring u=.5kx^2
Assuming the spring is compressed 6 inches and the spring rate is about 230 lbs/inch
That works out to about 350 ft-lbs of energy. Equivalent to the muzzle energy of a 9mm pistol point blank.
Yes, don't play with springs.
Just got it done this afternoon without a compressor and before seeing all your warnings and re-warnings… This morning, before I went to rent the compressor I wanted to finish to take apart the passenger side of my front end. To be sure to get to point where I will only have both springs left on the car.
Looking at 4uall last pictures before I started, I though "it should be feasible, why not on mine…" Then I noticed that I was able to spin the spring on itself as I was pumping with my feet on the lower A-arm. Imagine the scene, butt on the floor, feet on the A arm, hands on the spring… Not sure Fiat engineers designed to be done like that! Well, on the go I interpreted that as "there is not much compression left into it…" Then I decided to try to remove it like that messing up a little more with it. It finally came out on the passenger side, then I got the driver side same way. I did not wanted to try a crow bar or any tools, too risky in my opinion but I am glad that last chance thing worked well !
I will go and rent a compressor when I will put them back though, I don't want to push to hard on it and have the car fall from the stands or pinch my finger or anything as I push…
@ClarkTheShark: Thanks for sharing that formula, I will go to bed less stupid tonight, I really like to put science on top of things, but I am too lazy to look for it!
Now it's time for getting most of that refurbished !!
I am lazy and I got to ask, is there any smart trick to sand these springs? I was thinking wire wheel but not sure it's the smartest...
Olivier -- Excuse my French
1978 Fiat 124 spider 1800
Glad you got it apart. And I wasn't talking about compressing a spring 6", I was talking about an inch to make taking it out a bit more straightforward. I do this all the time. For decades. Still have all my fingers. Ya gotta have simple quick effective ways to work on cars or it takes forever.
Keith
Keith
Hi There!
While I was working on the refurbishing of the parts I am going to reuse, I noticed some where painted at some location, like the hubs having a 2 square inches of orange paint, the springs a long line of white and a few spots of green. Do you know if that was made on Fiat's fabrication lines for some positioning or parts identifications? I was just wondering if there was some history behind that or if it was one of the PO who made his personal color coding...
Also I noticed the center sway bar brackets are actually riveted together, no harm drilling them apart, but a pain to put back together I imagine…
Took a pic yesterday, here is the orange spot I found on 2 of the 3 hubs I have (2 from the car + one replacement for that striped stud).
I am curious of why is that although there no need to know why...
Also I am moving slowly but surely on the refurbishing of my parts,and I am almost done with repainting everything. Therefore I wanted a more rewarding DIY moment, so I removed the old A-arms, and replaced them with the new ones. I found something looking like washer/shims down there. One side had a lot of them, I removed half so the alignment shop may have something to work with.
I wanted to put back the springs, but I borrowed the wrong type spring compressor . Hopefully I will be able to find the good one and do that this afternoon.
By the way, anyone who know a good alignment shop in the south San Francisco Bay area?
the paint dot on the springs are factory. I'm sure the purpose is to identify years or weights of springs. I have see some markings on wheel hub but not on all. The shims you removed are for camber and castor adjust. I would put them all back in the same spot. Usually those are never messed with until you do an entire front rebuild and that was a factory setting.
Thanks Azruss, I love to know more about the history of these little cars! And on top of that I am sure my springs are still originals also!
Hi all,
I was about to paint the last part I need to put everything back together this week end if possible. I noticed that heat protection (to protect the Tie rod/centerlink Ball joints rubbers on top of the the idler) looks like bent in the left of the picture. I just wondered if that is the original shape or if it got bent at some point… Should I put it back straight if I can before I paint it, or is that odd curve normal?
- fiatmike124
Here is mine. The curve is not there.
Mike
1981 Fiat Spider 2000
2011 BMW 328i Coupe
2001 Mitsubishi Eclipse GT
2003 Yamaha V-Star 650
2011 BMW 328i Coupe
OK thanks a lot! I will have to bend it back then...
Hi There!
I am really happy about the progress I made yesterday afternoon! A friend of mine came to give me a hand, we got all the steering, the sway bar, the brakes, the hubs reinstalled and even got a chance to go for a short ride before the sunset, and a well deserved beer! What a pleasure…
Got that heat protection straightened up and mounted back:
All together, with a new used hub and 4 new studs:
However, without the proper tools I was unable to install back the rubber for my tie rods/centerlink: out of 6 I harmed 2 of them… I used a opened crescent wrench and hammered it gently to be able to push 2 sides of the ring at the same time and I guess the edge of the wrench pinched the rubber. Next time I will have to find a big socket or something else to make it smoother. I could even sadly watch the grease squeez out as I tightened everything!
(sorry for the blurry pic...)
If I have to make a few conclusion as a newbie:
- Buy/use the right tools, do not be lazy to do that extra trip to the hardware store
- O'Reilly is good for the specialty tools you will never use again,
- The grinding, sanding, painting, not so funniest part of it, is actually the longest one,
- I could count on luck as I did not face any big issues, but got a few times where you wonder if you are going to screw things up,
- Beware not to make your car fall of the jack stands (almost happened…)
- People on this forum are really helpful (thanks all),
- Most of the questions you ask yourself are also answered somewhere on the forum,
- The final result is rewarding! It's worth it…
- Make your budget and plan on spending 25% more,
- You can do it, just think twice before you do anything,
- I need more muscles, my 145Lbs did not helped me much…
Thanks for reading my post, and I hope I will come back posting on the forum soon with upcoming projects!
I sadly have to reopen this post…
I went under my car today for a transmission oil change thinking the challenge of the day was that PO rounded former 17 refill plug:
After putting the car on ramps, I crawled under it from the front and my eyes felt on that:
Several cracks on my crossmember. I am sure they were not there as I cleaned the area when I changed the A-arms…
The bigger one is above the mounting bolt, then there are 3 smaller ones along the bolt supports. Here is another pic from under it:
Two of the smaller cracks around the mounting bolt actually bent the steel of the crossmember. All of this is on the passenger side. I also noticed that one on the drive side:
Question 1 : Is that something common that happened before? I am curious what could have made that…
Question 2 : I am still a newbie, but if I can find someone who can weld over the cracks, is that a sufficient fix?
Also I had it aligned in a shop around the corner sometime in April, and I just took the car to go to work once every other week max, I did like maybe 200 miles of gentle cursing since I did that front end job on it. Is there any possibility that the guys at the alignment shop tighten all that too much and it cracked at the first bump?
