76 Fuel Vapor Pressure Relief Valve???
donerehart
Your car is a: 1976 spider
Post by donerehart »
I am trying to replace my 76 Fuel Pump and noticed my Fuel Vapor Pressure Relief Valve in the trunk is broken. It is a plastic filter of some kind that is mounted to the back wall next to the fuel pump. So it looks like these aren't available anymore (?)...what do I do to replace it? What have you all done? It is a two way valve that had two mounting bolts that mounted it to the back wall of tire well next to the old fuel pump. :(
76 Spider
St. Louis, MO
juvius
Your car is a: 79 spider
Re: 76 Fuel Vapor Pressure Relief Valve???
Post by juvius »
don... pm sent.. i have one you can have...
