DIFFERENTIAL SWAP
blusmith
Your car is a: 1982 124 spyder
DIFFERENTIAL SWAP
Post by blusmith »
DIFFERENTIAL SWAP. '82 Spider man is back on the road aftera rebuld But diff is terribly noisy despite being checked while out of the car , new oil etc . I was told that it was NOT a spideer diff and might have come from a Fiat 131 (!?) Can the experts tell me what diffs are interchangeable with a gen 124 spider set up because I will have to source a second hand here in New Zealand and repair it. Thanks Chris
divace73
Re: DIFFERENTIAL SWAP
Post by divace73 »
The 82 had the 131 style of diff ( in fact from around 78 onwards)
Cheers David
see my >>You tube channel<<
the 131 ratio was different than the Spider
BEEK
Your car is a: 1975 Spider
Post by BEEK »
the 131 diff has different angle on the upper brackets, and drum brakes here in the usa. both issues can be solved, the brackets from a 124 can be welded on, and the drum brakes can be changed for disc, from a 124 too.
i would check the ratio, like mark said
75 spider
son has 78 spider
blusmith
Post by blusmith »
Thanks everyone - I now know where to start.
djape1977
Post by djape1977 »
131 'had 3.7, 3.9 and 4.1 ratio depending on the engine size. smaller the engine, shorter the ratio.
diesel and automatic would have had 3.7 or even longer
