Engine Mount Torque
aj81spider
Engine Mount Torque
Post by aj81spider »
I am slowly getting to the point of re-installing my engine. Last step before re-installing was to change the engine mounts. Two questions:
> It looks to me like I shouldn't tighten up the engine mounts until the engine is attached as the engine mounting hole is a hole, while the cross member has a slot. Am I correct in this?
> More importantly, what should I torque the nuts to? I can't find that in any of the manuals I have.
Thanks for the help
A.J.
2006 Corvette
Tobi
Re: Engine Mount Torque
Post by Tobi »
I did the mounts and the brackets after I moved the engine back in so I had more space in the bay. I don't thing people use a torque wrench on that, I did not.
