Another Identification Question
aj81spider
Post by aj81spider »
As I plan the re-installation of my engine into the car I'm left with a few items I'm not sure of. I've been searching and can't find what this (the thing behind the carburetor mount) is.
It frankly looks broken (one of the two ears on top), so I may even need to replace it. Any guidance would be appreciated.
A.J.
2006 Corvette
Re: Another Identification Question
it's a thermovalve for the egr system
aj81spider
Thanks Mark,
Can I pull it out and seal the hole then?
A.J.
2006 Corvette
johndemar
Your car is a: 1976 Fiat 124 Spider
Post by johndemar »
As long as you don't need to be concerned with emissions testing,it can be plugged.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
aj81spider
Thanks - no emissions testing for cars this old in Massachusetts.
A.J.
2006 Corvette
aj81spider
I did a little more research and have a question. Is it true that there is a cooling passage to the valve?
If that's true then do I need a minimum length plug?
A.J.
2006 Corvette
Dougieb
Your car is a: 1972Spider
Post by Dougieb »
I plugged mine with no problem.
No, there is nothing to worry about.
The thread depth is not very much.
Pull yours out and you will see.
It is either a 16mm 1.5 pitch or 18mm 1.5 pitch (I forget).
You can get oil pan plugs at most auto parts stores in both sizes.
I used teflon tape just to be sure there were no leaks.
Good luck.
vandor
Post by vandor »
Yes, there is coolant below the valve.
It does not matter, I don't think the plug will thread in more than a few turns.
aj81spider
Thanks for the replies. Plugging is in process.
A.J.
2006 Corvette
