Hissing brake peda
Juarez
Hissing brake peda
Post by Juarez »
Hissing brake pedal and becoming more difficult to push down. I feel like I broke something. Doing some research on the forum I'm thinking its the booster? Checking the fluid tomorrow, and taking it from there.
narfire
Re: Hissing brake peda
Post by narfire »
Pooched booster. Recently replaced mine as it had the same symptoms. Takes 1-2 hours.
Juarez
Post by Juarez »
Thats unfortunate. Thanks for the quick response!
Juarez
Post by Juarez »
Where did you get your replacement brake booster from?
narfire
Post by narfire »
Juarez wrote:Where did you get your replacement brake booster from?
I put an add out on the local Craigslist, well sort of local.. Vancouver BC(400 kms away) and a fellow had one that was good for $40.00
Take a look in the parts section here and enquire about a booster. New they are a bit pricey.
Juarez
Post by Juarez »
Gottcha I'll put some reques out there. I appreciate it.
profcucchi
Your car is a: 1979 Fiat 2000
Post by profcucchi »
If I can chime in quickly:
I had similar problems and had the master cylinder and brake lines bled. Worked like a charm. Have you had the brakes worked on recently?
Otherwise its the booster.
1979 Fiat 2000 "Luigi"
tartan18
Post by tartan18 »
I have a booster that I took out of my 1975. It worked fine but I replaced it with a new one :D You can have it for the cost of postage. PM me if interested.
Jim MacKenzie
1975 Fiat Spider
