Rattle in Stick
unplugged
Your car is a: 1981 Spider
Rattle in Stick
Post by unplugged »
AT 4000 RPM I get a pretty big rattle in the stickshift. I got under the car and took of the plate and inspected the nut holing the stick in and it was tight. I recently had the Ring & Pinion replaced in the rear end and I lost 4th gear.
Could either of these be the cause?
Any suggestions on how best to track it down?
'81 Spider
BEEK
Your car is a: 1975 Spider
Re: Rattle in Stick
Post by BEEK »
it is most likely the bushings in the shifter extension. this is the chrome part that sticks over the shaft from the transmission, there are 3 rubber bushings and 2 nylon pieces inside
75 spider
son has 78 spider
courtenay
Re: Rattle in Stick
Post by courtenay »
There's plenty of info on this problem in other threads. Do a search on "shift rattle" and you'll come up with all kinds of potential solutions.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
