Three (was two) newbie carb quesitons
tdskip
Your car is a: 1968 Spider
Post by tdskip »
First - I did look for markings so not being totally lazy :D
Is this a 34DMSA?
Second - is this my idle adjustment screw? Basically from cold she starts and idles around 600 RPM, but when hot she races at 2000 RPM. Don't think it is my manual choke keeping the RPMs from dropping becuase otherwise it would do that from cold idle.
Thanks!
tdskip
Re: Three (was two) newbie carb quesitons
Post by tdskip »
I should have a choke here where this blanking plate is, right?
majicwrench
Post by majicwrench »
That screw is the idle MIXTURE screw.
Nope, that plate does not cover or replace any part of choke.
Keith
tdskip
Post by tdskip »
Ah - OK. Learning as I go here.
So where is the choke on this carb then?
Thanks Keith
lanciahf
Post by lanciahf »
Choke should be manual, Is there a cable going to the side of the carb, closest to the firewall?
georgeramos
Post by georgeramos »
what are all the markings at the base of the carb? looks like theres stuff there...
tdskip
Post by tdskip »
Hi guys - good to be back and poking at the Spider again.
George - no stamping there, just some scratches.
My choke cable attaches to the throttle as it is currently set up - I could just about drive the car around using the choke cable instead of the accelerator. When the choke is engaged the pedal actually travels down to the floor. Maybe my British cars have me flummoxed here, but this can't be right. Can it?
majicwrench
Some of these Fiat have a throttle CABLE down by the choke cable that will run the throttle just like the gas pedal. Is there another cable on the other side of column??
Keith
tdskip
Post by tdskip »
majicwrench wrote:Some of these Fiat have a throttle CABLE down by the choke cable that will run the throttle just like the gas pedal. Is there another cable on the other side of column??
Keith
Oh, you mean on the one on the left that says "CHOKE"?
Holy cow I'm a dolt, never saw it there Keith. My TR6 / MGC don't have a throttle cable like that so I assumed it was a poor Italian translation.
124JOE
Post by 124JOE »
the one on the left is a 32/36 dfev 1972 i think
the one in the middle is a 32/32 adfa 1978
the one on the left is a 32/28 1979-80
in this pic i am pointing at the stamp with id code,this carb uses a vacum secondary barrel
32/32 this carb has mecanical secondarys
32/36 this carb has mecanical secondarys
