Transmission Oil Change RESOLVED sorta
4uall
Re: Transmission Oil Change RESOLVED
Post by 4uall »
:D :| :? :shock: HULK SMASH! :mrgreen:
Exit98
Post by Exit98 »
If you drain the tail section as described above, you will need to check and add oil after running the car a little.
Oh damn, Bernie, thanks to you now I have to go back and top up the trans oil.
Shoot.
roanokeSpider
Post by roanokeSpider »
I used a 5' section of 1/4" tubing to fill the trans and diff. The fill holes are close enough to the outer diameter of the tube that it stays in place then add a funnel and gravity it will be filled. The drain plugs on my car were stubborn but with encouragement from a heavy hammer on the end of my ratchet they freed up.
I don't want to be a dick, but if anyone already has a picture of the small 7mm drain plug location for the rear chamber, can you post it? For God's sake don't crawl under there and take a pic, but maybe somebody already has one?
Pete
Razooli
Your car is a: 1982 Fiat Spider 2000
Post by Razooli »
RRoller123 wrote:... picture of the small 7mm drain plug location for the rear chamber
... had one. :D
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
focodave
Post by focodave »
1970 MGB GT (my other hobby)
focodave
Post by focodave »
Ha!
Razooli beat me to it.
My plug was VERY tight.
I used large vice-grips to get it loose and all is well....
Thank you gentlemen! If it is true that about a pint gets trapped back there then I will be changing this out completely (again... :roll: ) very soon! I can't verify that the PO used the correct fluid, and I have driven a few thousand miles with what I thought was all new fluid, but now it turns out it was maybe only 66% new fluid. :shock:
4uall
Post by 4uall »
@ Fazooli & Focodave you guys ROCK! 8)
@ RRoller123 Ditto. I guess I will have to get under Fiona again :roll: Does anyone sell the bolt in case of damage on removal :shock: ? Going to order the trans gasket and replace at the same time :mrgreen: (silver lining)
Specialk
Your car is a: 81 Spider 2000
Re: Transmission Oil Change RESOLVED sorta
Post by Specialk »
Hi,
How do you know when you've filled with enough oil? Just keep on filling until it backs-up outmofmthe fill hole?
Rgds
I think that is correct, and if you drain the rear compartment, I ASSUME that it should spill over into said rear compartment before it overflows the fill hole?
baltobernie
Post by baltobernie »
I dunno. The Fiat mechanic who rebuilt my transmission said to add one quart to the dry tranny, cap it and tilt the thing upwards. Hold for a little bit. Return to level and fill normally. This implies that oil is circulated throughout during operation, but would not flow rearward assembly unless the transmission was turning.
(With a dry transmission) I suppose one could fill normally, carefully run the car on the lift or jackstands for a minute or two, then top off.
BTW, while I have ranted here ad naseum about the unsuitability of modern engine oils to lubricate our Spiders, I have nothing but praise for Redline MTL in the gearbox. Stuff is slicker than goose s#%t; makes those cold-start shifts just as easy as fully-warmed. No "glitter" or anything sticking to a magnet after 10k.
4uall
Post by 4uall »
:shock: DID SOMEBODY SAY "GLITTER"?! :shock:
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Post by giuliot60 »
This is similar to what I used to get the GL1 into the transmission. About $8, although I think I paid $12. Easiest thing to do. The tube fit in perfectly.
Napa Part Number: BK 7151245, Product Line: Balkamp, Fluid Capacity: 1 PT
http://www.napaonline.com/Catalog/Catal ... 0361153566
Giulio/Charlotte
Ellie
Your car is a: 1982 Pininfarina Spider 2000
Post by Ellie »
Great thread.
The shop manual I have says use non EP but the trend I get from this forum is that 80/90 GL5 EP is the best way to go. Also, does the same oil go into both the transmission and Diff?
Cheers
