Leak from Exhaust Manifold
esodu
Your car is a: 1980 2000i Pininfarina
Post by esodu »
I am getting white smoke coming from the engine and I have been troubleshooting the problem, and I think I found the leak.
I removed the heat shield and what I can see is that the smoke is coming from (at high RPM) the top of the downpipe for the exhaust and the bottom of the exhaust manifold. There looks to be a paper gasket in between, but I can't seem to find it anywhere online as a replacement part. Does anyone know where I can find it and what it is called? Is there any other options to fix this rather than disconnecting the downpipe from the exhaust manifold and replacing the gasket? Any help would be appreciated!
Re: Leak from Exhaust Manifold
there are no options other than replace it. That gasket is called an exhaust flange gasket. White smoke is a concern though; it can indicate burning oil or if it's steam, a leaking head gasket.
esodu
Post by esodu »
Mark
I just came across this post - http://fluforum.italiancarclub.com/view ... hp?p=11179 where they state there shouldn't be a gasket in the 1980 FI version. It' has one in it today, but I don't think it was original from the looks of it. You mentioned the smoke concern. I may be off on the "color" - it's smoke, I used white to differentiate it from blue. I am not getting any "colored" smoke out of the exhaust. Not sure if I should be overly concerned, but any suggestions in determining if it's something I should investigate further??
Thanks for the help.
Ed
right, an 81 shouldn't have a flange gasket but you didn't state the year of the car in the first post. If it's smoke and not steam, it's probably oil smoke
esodu
Post by esodu »
Sorry about that. It's a 1980. Would that be the same as the 81?
narfire
Post by narfire »
6 studs....the same. the 79 and later 6 stud exhaust manifold-to down pipe does not have a gasket. Metal to metal.
