Oil
Re: Oil
First of all, as far as I know Fiat engines have not had troubles because of oil with lower zinc contents. So it may be a non-issue, but I guess we don't really want our cars to be the testbed...Kent124 wrote:So I've heard Rotella is now reformulated with lower zinc for modern diesel engines.
Are most of you now using a ZDDP additive? Or are you using Valvoline Racing 20W50 NOT STREET LEGAL or the equivalent?
I've used the Valvoline VR1. It will mess up the converter if the car has one, so I only use it on non-cat cars. I've also been using Castrol GTX in my own car with no ill effect so far.
Re: Oil
I used 20w50, but it gets hot here in Texas. If you live in a milder climate I recommend 10w30. Fiat recommends that grade for temperatures up to 95F.Kent124 wrote:I've been using 15w40 Rotella. VR1 comes in 10w30, 20w50, SAE30, SAE40. Which would you recommend?
Re: Oil
I just did an oil change after buying the car 2 weeks ago. Lucky for me, the old salty dog that works at Part Source has an old Fiat as well. He recommended a 5W50 synthetic (Castrol). I also picked up a magnetic drain plug bolt.
Hope this helps,
Hope this helps,
- 124ADDHE
Re: Oil
Not to nitpick here guys but the fiat workshop manual states no thinner than a 15-40 unless you are below -15 (5F)....I run 15-40 in the winter, keep my car outdoors and can start and run in the coolest temps but i have a block-heater. 20-50 in summer.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
- kilrwail
Re: Oil
I used Castrol GTX 20W50 for over thirty years, until the API category changed to SL. I now use Brad Penn 20W50 which retains a high ZDDP content (over 1300 ppm), in both the Spider and Porsche.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
Re: Oil
The 1971 owner's manual lists several single and multi-weight grades and their temp ranges. 10w30 is recommended for temps up to 95F.124ADDHE wrote:Not to nitpick here guys but the fiat workshop manual states no thinner than a 15-40 unless you are below -15 (5F)....
Re: Oil
I too looked at the owners manual however, as my mechanic informed me these manuals are 30+ yrs old and technology has changed etc. That being said everyone has different methods so as long as there is oil in her that's a start
- 124ADDHE
Re: Oil
Ok, my manual is dated 1990, so maybe thats why there is a difference. Anyway, 30 @ running temp seems light to me, but I like rpm
Regards,
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
- kilrwail
Re: Oil
The 1978 owner's manual calls for SAE 30 or 20W40 between 32 F and 95 F.
Peter Brownhill
Peter Brownhill
Re: Oil
Thought I would give this thread a little bump, as I am about to do my spring oil change I am going to go and pick up
and some 80/90 for the differential (transmission change was already completed)
let the comments begin
Re: Oil
To be used in my differential oil
