Hello,
I just got an 83 Spider and I need to change the harzard switch as it is defective and prevents my blinkers form working. I managed to get the blinkers operational by bypassing the hazard switch but I hope it will only be a temporary measure.
Now, how do I remove the darn switch so I can either fix it or replace it?
I tried everything I could think of but something obviously eludes me.
Thanks in advance.
83 spider hazard switch removal. How?
Hazard switch removal
You have to push it from the back and the switch should just pop out. I think you can get your hand in from under the glovebox or remove the glove box insert. Don't try and pry on the bezel for the switches/lights. It is held tight by the switches.
John
Kansas City
John
Kansas City
