Hi guys,
I just was given a 1980 fiat spider FI 2000 that hasn't been started in a couple of years. It was garage kept with a dry fuel tank and overall is in great condition. I changed all the fluids, put in a new battery, and added some marvel mystery oil into the spark plug holes and I'm now trying to start it up . First time trying the starter was seized, banged on it abit and it freed up like a champ. Now it will turn over, but wont fire, from what i can tell its not getting fuel. Before i start tearing into the fuel filter and fuel pump is there anything to do/check? Any advice is much appreciated.
thanks
turns over, no fuel.
Re: turns over, no fuel.
the fuel pump may be seized due to fuel varnish. An empty tank is a bad thing, since they usually will rust when left like that
Thank you, that makes sense. With that said is recommended to swap the fuel pump or is it possible to get it freed up?
