Timing
fiat218
Timing
Post by fiat218 »
I have a 79 124 2.0. Dual carbs
Timing is off but when I time it by ear it runs great, excellerates quick and no popping
But when I shut it off ,it has a hard time turning over, prolly to advance
I have marks ignition set up,
What shall I do
SLOSpider
Re: Timing
Post by SLOSpider »
Retard the timing a bit a little at a time till you get good power and easy starting.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
kustom
Re: Timing
Post by kustom »
Have you checked static timing on the crank and cam gears? If you can confirm this is correct, I would time it to 10 degrees BTC... if you have a timing light.
Phill
1981 Spider
2014 Ram 1500 Eco Diesel
2007 Acura TL
Re: Timing
we suggest setting initial timing at 12btdc with our ignition system
fiat218
Re: Timing
Post by fiat218 »
thanks , it better, what was wrong was the carb screw was set all the way in, i did the 1 1/4 tirn out and now it dont pop and starts better
thanks
georgeramos
Re: Timing
Post by georgeramos »
DUH!
just kidding Jim
But seriously how does it run with Marks system? I am very interested in that setup, particularly any increase in rev/power.
fiat218
Re: Timing
Post by fiat218 »
georgeramos wrote:DUH!
just kidding Jim
Lol it ok ,I can take shit :) and give it
