Mixing Engine Oil Weights
SeldomSeen
Your car is a: 2018 Fiat 124 Spider
Post by SeldomSeen »
I really needed to top off my oil today after tightening a leaking oil pan. My 124 usually gets Castrol GTX 10W-40 but all I had on hand was Castrol GTX 5W-30. Was that a bad idea?
It's never too late to have a happy childhood - Tom Robbins
1972 Alfa Romeo GTV 2000
1966 MGB Roadster
2007 MINI Cooper S
2018 Fiat 124 Spider Classica
divace73
Re: Mixing Engine Oil Weights
Post by divace73 »
Just my personal opinion and by no means am I an oil expert but it is better to have a mix in than no oil at all, just do a full oil change sooner rather than later......
Cheers David
see my >>You tube channel<<
htchevyii
Post by htchevyii »
Should be fine, especially since they are the same brand, (same additives etc).
Trey
mix and blend to your hearts' delight, the only thing that changes is the viscosity when you mix different weights
SeldomSeen
So running Castrol GTX 8.75W- 37.5 is okay. :) Thanks much.
1966 MGB Roadster
2007 MINI Cooper S
