Intake question.
Intake question.
Sense my car used to be Furl Injected , P/O change it too carb setup. How do I tell what intake I have now?
Untitled by fiatcs2000, on Flickr
- SLOSpider
Re: Intake question.
That's a carb intake...but really I don't know what year maybe 1980? Also that plugged off nipple below the carb on the back of the intake is where your brake booster vacuum line goes to FYI .
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Take the carb off and look down. If its is just one open hole, it's a single plane. That's the one you want. If it is divided its a duel plane from a 2L and you will want to replace it.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
I'd be guessing a head from a 79 or 80 carb'd car, perhaps even an 1800 head. Intake looks like a duel plane (bin-it)
On the intake manifold I see the air passage to the front but on the exhaust side I don't see it, but do see a casting on the towers for air pump? or some smog device. Mechanical fuel pump is blocked off. Is there a smaller capacity electric fuel pump (not the FI hi-pressure pump)?
The FI head/towers do not have that casting.
Looks a bit of a hodge-podge. Still, a 2L block is a good engine . Take a look at the casting numbers on the head and see what they might tell you.
Chris
Chris
Yeup...off to the recycle bin...
- SLOSpider
Now with that pic I take it back the larger vacuum fitting on the left is the booster one most likely. You don't have to get a different manifold as that one should work just fine.
1975 124 Spider
That's a duel plane. For optimal performance you will want the single plane.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
perhaps we should ask what carb were you looking at installing? The dual plane was good for the 28/32 only as the secondary opening is too small for anything else.
When you have a moment take a look at this site. Click on the blue manual
Page 84 kind of sums it up
http://www.artigue.com/wp-content/uploa ... 124_MM.pdf
If you post in the parts wanted, I'm sure there will be a single plane manifold out there. I believe a riser is often used as well.
Chris
Chris
It has the weber 28/32 ADHA now I do not like it, it has the vacuum secondary I would rather have a manual. I am thinking maybe IDF carb....
Cool, idf's can get expensive but ask around regarding the 32/36 carb's many have swapped over to. Need a single plane intake. The 34 dmsa or 34 adf is another choice some are running as well. Just a bolt on improvement..
Another thing about idfs is you'll benefit the most if you upgrade the pistons and(/or?) cams. So if you don't want to put more nods in to up the compression, then go with a single 34 like narfire says.
