Ok, Which one is correct?
A - Spring resting on the back of the caliper applying pressure outward.
B - Spring between the angled shim and caliper bracket.
A - looks like the way it was designed to work with the spring resting on the angled cut on back of the caliper but car had them installed like B.
Caliper Spring Clips Install
Re: Caliper Spring Clips Install
A is correct, I've seen them assembled like B also, but that binds the caliper and won't let it slide. Also, the sliding pieces should be lubricated with a caliper grease. Bendix ceramlub is the best
Thanx Mark!So Cal Mark wrote:A is correct, I've seen them assembled like B also, but that binds the caliper and won't let it slide. Also, the sliding pieces should be lubricated with a caliper grease. Bendix ceramlub is the best
Yeah, It didn't make sense to mill out the back for no good reason.
This is just a temp assy to check fit.
I will pull the calipers and bead blast them before hi temp painting them too.
The brackets silica blasted nicely and have VHT paint on them.
