brake booster vacuum hose
westy64
Post by westy64 »
hello,
I take the opportunity of the work on Prunette to replace the vacuum brake booster hose.
The one in place used to be a long one, making a loop between the intake manifold and the brake booster, when the two plugs are right in front of each other.
The hose could go straight from the manifold to the booster.
Is there a reason for this hose looping that way ?
Thank you for your help.
Jean
Re: brake booster vacuum hose
the motor mounts are rubber, so there is some movement of the engine when it's under load.
rodman
Post by rodman »
Does anyone have a extra one? Mine was not on the car when I got it...
BEEK
Your car is a: 1975 Spider
Post by BEEK »
you need to call me and come by, as you are only 20-30 miles away. i have parts cars too
75 spider
son has 78 spider
why would you want to put on a used hose to the brake booster?
rodman
Post by rodman »
BEEK wrote:you need to call me and come by, as you are only 20-30 miles away. i have parts cars too
Damn Beek forgot all about you..... Ill try come up this week.
rodman
Post by rodman »
So Cal Mark wrote:why would you want to put on a used hose to the brake booster?
The insert that goes into the Booster was missing the whole thing, The only thing that is there is the Rubber ..
