1981 FI Spider- No start
Re: 1981 FI Spider- No start
clogged injectors?
rlux4
Post by rlux4 »
At this point we can't tell if the injectors are clogged or not, they're not getting pulse signal.
Ron
Ron Luxmore
rlux2n2@gmail.com
got it.
jcuje
Post by jcuje »
Hi all,
Thanks for all the feedback. I have a new noid light kit that I'm going to use to verify if I have pulse. I will be sure to check into the forum once I've performed the tests suggested.
Jeff
jcuje
Post by jcuje »
Hi all,
Jeff
Cal124turbo81
Post by Cal124turbo81 »
Hi Jeff,
Were you able to get this issue figured out. I think I am having a similar issue. I am not getting any signal to the injectors.
Thanks!
Adolfo
