Air conditioning system.. Keep or remove ?
AZ124Fiat
Post by AZ124Fiat »
On most cars it is benificial to keep an A/C system in a car, curious what the thoughts of the forum are. Getting ready to start my resto and doubt my A/C system works anyway.
azruss
Re: Air conditioning system.. Keep or remove ?
Post by azruss »
I pulled the AC out of my 80. I did it for the following reasons.
In AZ, i didnt want any more burden on the cooling system and horse power
It removed clutter and weight from the engine compartment
Gave leg room back on the PS
SunnySideUp
Your car is a: SOLD
Post by SunnySideUp »
My understanding is that a Spider with A/C is pretty much a United States "thing." I don't think the car was ever intended to host an A/C system. I would say it's a personal preference thing at this point. Depending on how often and where you drive the car coupled with your comfort level would dictate whether to keep or remove the A/C. Typically, the A/C comes out if you want more power from your engine. It's one less thing to fight with or maintain in the engine bay. And, like azruss said, getting rid of it gives the passengers more leg/knee room.
SunnySideUp
vandor
Post by vandor »
If you kept it then be prepared to replace most of the AC components. You can likely reuse the under dash unit and the compressor bracket, and renew everything else.
DeanJones
Post by DeanJones »
AZ124Fiat wrote:On most cars it is benificial to keep an A/C system in a car, curious what the thoughts of the forum are. Getting ready to start my resto and doubt my A/C system works anyway.
The older I get the more I wished I had one in my Spider. Live in Adelaide, Australia which I suspect has a fairly similar climate. (close to 40 degrees here today, and a low last night of 27). The large black fabric roof within cm's of ones head if the roof is on or with roof off and stationary at the lights...... not fun in the warm summer days.
If I could find one that was discrete in the interior, works well from a cooling and reliability perspective I would put one in mine.
Regards, Dean
divace73
Post by divace73 »
I'm with Dean on those hot days, mostly it is not needed, but on those hot and humid days when it is needed I wish I had it....
I don't know if there are more effecient units around now??
Cheers David
see my >>You tube channel<<
AZ124Fiat
Post by AZ124Fiat »
Thanks all..
I am sure the system is in need of repair anyway which could cost hundreds. Best to remove it and keep it on a shelf for the future.
Warren
Post by Warren »
I installed the Factory Air one from Texas several years ago and it works well as long as outside temp is 95 F or below. Too much top in-leakage at higher temps and highway speeds. No overheating problems either. I have some photos/tips on my installation if needed.
http://factoryairconditioning.com/searc ... 4%20SPIDER
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
