Fiat 124 engine
harrinad
Fiat 124 engine
Post by harrinad »
I recently took apart a 1972 Fiat Spider 124 and it looks like the engine has been swapped. I am reasonably sure that it is an 1800 but I'm not sure how to tell what year it is. My concern is I think it may be out of a 1974 and the two engines require different parts for the rebuild. Can anybody help me figure this out? Is there a part number or something I can chase?
Re: Fiat 124 engine
BEEK
Your car is a: 1975 Spider
Re: Fiat 124 engine
Post by BEEK »
look just above the oil filter housing and let us know what numbers are stamped there
75 spider
son has 78 spider
harrinad
Re: Fiat 124 engine
Post by harrinad »
Does 132 040.4 look right?
BEEK
Re: Fiat 124 engine
Post by BEEK »
thats a 1974, 1800
75 spider
son has 78 spider
Danno
Re: Fiat 124 engine
Post by Danno »
Mira has a good chart on this, too. I was just using it the other day to ID the engine in my 128:
http://www.mirafiori.com/id/tableeng.html
here's the one with the Car model and engine code:
http://www.mirafiori.com/id/table124.html
harrinad
Re: Fiat 124 engine
Post by harrinad »
So this is my engine?
132A1.040.4 DOHC 1756cc 84.0mm 79.2mm 8.0:1 5-53/53-5 Carb. Federal 86
86 hp stock?
BEEK
Re: Fiat 124 engine
Post by BEEK »
yes, but with a few minor modifications you can get a whole lot more out of it.
75 spider
son has 78 spider
djape1977
Re: Fiat 124 engine
Post by djape1977 »
107hp standard and 111hp in "special", both with single carb, euro-spec
opus10583
Your car is a: 1978 CS1
Re: Fiat 124 engine
Post by opus10583 »
djape1977 wrote:107hp standard and 111hp in "special", both with single carb, euro-spec
Hi,
What's that "special" tune?
Mark
djape1977
Re: Fiat 124 engine
Post by djape1977 »
1974-1977 fiat 132 1800 special. 1756ccm with long duration cams and 42.5mm intake valves. found in europe and australia.
