Garion's Head
BEEK
Your car is a: 1975 Spider
Garion's Head
Post by BEEK »
Received head today @ 2:45pm. Began teardown, and cleaning process.
Beginning teardown, Removed cams and housings. Placed them in the cleaner
Removed valves, notice the heavy carbon deposits on the intake valves. Cleaned the valves, Cut the valve faces
Head after valves removed, ready for cleaning
Cam housings out of cleaner, Hardware cleaned up.
75 spider
son has 78 spider
garion
Your car is a: 1979 Fiat 124 Spider
Re: Garion's Head
Post by garion »
Beek, thanx for this! I can't wait to get it back...
--John
--John
2007 Audi A4
BEEK
Re: Garion's Head
Post by BEEK »
should have it finished by mid morning. if all goes well it should be back in route to you tomorrow. Call me tomorrow. Thanks
I'll post pictures of the rest of the rebuild including completed pictures tomorrow
75 spider
son has 78 spider
131lover
Your car is a: 131 supermirafiori
Re: Garion's Head
Post by 131lover »
Hi BEEK,Garion, ALL!
Are you running the Fiat express rebuilding/tuning shop? fast work !
What kind of work are you going to do with the head ? Whats the goal, just rebuild?
Best Regards
Alf Andersson "131lover"
BEEK
Re: Garion's Head
Post by BEEK »
work being performed is a standard valve job, resurface and cleaning. disassembly and reassembly and valve adjustment.
This will give him the head in "ready to bolt on" condition. I do offer performance work as well, including porting, big valve installation, degree camshafts, guides etc. im not a parts supplier i recommend using the sites vendors for camshafts, valves and gaskets.
75 spider
son has 78 spider
BEEK
Re: Garion's Head
Post by BEEK »
update: head cleaning completed, cut the seats, resurfaced the head. then ooops....
inspecting all the threaded holes in the head i found this: #3 spark plug hole. first picture is of #2 all good
helicoil to be installed in the morning!
Then came reassembly, valves were lapped, springs checked, valve seals installed, valves and springs installed.
cams were installed, valves were adjusted
job completed except for the helicoil in the morning
75 spider
son has 78 spider
baltobernie
Re: Garion's Head
Post by baltobernie »
What a cool thickness gage! Batteries not included 8)
garion
Re: Garion's Head
Post by garion »
Looks good!
Odd about plug 3 though.. I've taken out, put in the plugs a couple times since I had the car, never a problem with that plug. In any case, it'll be fixed!
Now I'm going to have to clean the rest of the engine bay, cause that head looks so good. *sigh*.
--John
2007 Audi A4
dantye
Your car is a: all gone
Re: Garion's Head
Post by dantye »
BEEK wrote:update: head cleaning completed, cut the seats, resurfaced the head. then ooops....
Post reads that most photos were removed. Was this intentional or just a glitch? What yr. engine is it? Thanks
BEEK
Re: Garion's Head
Post by BEEK »
sorry i moved files into a folder in photobucket, didnt know it would effect the pictures being viewed, i put them back, all is good now. this is an 1800 head. 1974-1978
75 spider
son has 78 spider
garion
Re: Garion's Head
Post by garion »
To be more precise: Its a 78.
--John
2007 Audi A4
BEEK
Re: Garion's Head
Post by BEEK »
This is the insert and the insert installed.
75 spider
son has 78 spider
131
Re: Garion's Head
Post by 131 »
BEEK wrote:i put them back, all is good now.
Nope, still missing photos.
Mick.
ga.spyder
Re: Garion's Head
Post by ga.spyder »
Beek,do you have any pix to put up of the race head you are doing for our Lemons car?
Craig
Craig Nelson
Fling It Around Turns !
BEEK
Re: Garion's Head
Post by BEEK »
yes, ill make a thread for it tomorrow, both will ship tomorrow
75 spider
son has 78 spider
