cable routing
rja
Your car is a: 1974 124 sport
cable routing
Post by rja »
has anyone a diagram/picture of the window regulator cable routing? '74 124 sport 1800. or maybe a link? this haynes manual is virtually useless. :shock:
if you can't be an example, be a warning.
divace73
Re: cable routing
Post by divace73 »
i believe there are only 2 wires?? swap them around if your switch is wrong (or turn switch upside down?)
Cheers David
see my >>You tube channel<<
rja
Re: cable routing
Post by rja »
maybe i wasn't clear. this particular car has manual window cranks and the cable i was referring to routes around several "spools" or guides inside the door to facilitate the actual movement of the window within its two vertical tracks.
vandor
Re: cable routing
Post by vandor »
Take the other side doorpanel off and copy its routing.
azruss
Re: cable routing
Post by azruss »
dmwhiteoak
Re: cable routing
Post by dmwhiteoak »
A set of dental pics (that's what I call them ) will come in very handy.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
divace73
Re: cable routing
Post by divace73 »
rja wrote:maybe i wasn't clear. this particular car has manual window cranks and the cable i was referring to routes around several "spools" or guides inside the door to facilitate the actual movement of the window within its two vertical tracks.
sorry bout that, should have picked up it was a pre80 eliminated the electric window :oops: unless of course a PO performed the electric window shuffle upgrade??
Cheers David
131
Re: cable routing
Post by 131 »
rja wrote:this haynes manual is virtually useless. :shock:
That would be the infamous "toilet paper edition".
Mick.
rja
Re: cable routing
Post by rja »
you guys are very informative. and funny, too. :lol: and i'm thanking you very much. heater core is next. :roll:
81SPIDERMATT
Re: cable routing
Post by 81SPIDERMATT »
rja wrote: heater core is next. :roll:
MARK SELLS THE METAL TUBES THAT WILL MAKE YOUR LIFE EASIER
rja
Re: cable routing
Post by rja »
i'm all for making this easier. got an aftermarket a/c unit hung under the dash right in the way. this should go to another post.
rja
Re: cable routing
Post by rja »
update on the window regulator-task completed. w/much white lithium grease applied everywhere it could be; all over the glass included :oops: thanx to everyone again for input and to twincam for expediting the rollers.
tmooretxk
Re: cable routing
Post by tmooretxk »
what tubes and who is Mark/twincam?
rja
Re: cable routing
Post by rja »
hey-the tubes have to do w/the heatercore replacement i did after the window regulator replacement, and mark is the site owner, i believe. twincam is a fellow site member that was courteous enough to supply me w/some of the window "rollers" i needed. :) :)
Hudini
Re: cable routing
Post by Hudini »
i need help with my power window. I make a new cable. But, i can't make it right. I see that cable must be wind 3 times on drum. Which cable, this which go on lower rollers or cable that goes to upper rollers. I'm going slightly mad....
7 day I try..oh boy...
How long this cable is suppose to be??
When I buy this Spider driver window did not work. It's a 1979 Spider.
