Rumbling noise on acceleration?
Fiat88
Post by Fiat88 »
Don't really know what is causing this but have an idea. When I start out from a dead stop I get a rumbling noise and slight vibration near the automatic trans shifter before its shifts into the next gear. Does this mean my auto trans is messed up? I do get a clunk when I shift into reverse also.
Trans filter and fluid are new but I do have a small trans leak still so I always check on the level. Front motor mounts are new but the trans mount needs replacing. Would a bad trans mount do this?
The only thing thats strange is the noise I remember became more apparent when I had a new muffler put on. :?
Any ideas whats going on here? Thanks.
4uall
Re: Rumbling noise on acceleration?
Post by 4uall »
I know exactly what that is..........................................it is the trans holding back all the immense power of your Fiat :shock:
No idea sorry :cry:
Post by 131 »
Tailshaft uni joint/s and/or centre bearing would be my first point of call.
Mick.
also could be the trans mount has failed, letting the trans bounce up and down under load. I'd look at the driveline and mounts soon
Fiat88
Post by Fiat88 »
Thanks guys will check it out.
markintheair
Your car is a: Fiat 124 Spider 81 FI - Corsa Rosso
Post by markintheair »
I actually have the same problem, only difference is that i have a 5-speed instead of an automatic. Thought it might be a problem in the differential.
Only the fool looks at a finger that points at the sky.
'81 FI Spider 2000
