Post pics of your spider lowered ,
akavinn1
Post by akavinn1 »
Can everyone post pics of there spider lowered , with they types of springs u have maybe even before and after .
jfrawley
Your car is a: 1982 Spider
Re: Post pics of your spider lowered ,
Post by jfrawley »
Before
After taking one round out of the front and 1.5 rounds out of the rear stock springs.
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
akavinn1
Post by akavinn1 »
Wow looks so much better what an improvement !! How is the ride now ?
What size wheels was that spring lowering done with?
fiathead
Post by fiathead »
This is a shot of my Spider when I first got it. The factory springs where heavily cut by the Jerrari shop and were basically shot when I got it. (the link shows the photo better)
Here it is today after a set of lowering springs were added. The springs were a set of the yellow springs from Vick Autosport with one coil cut off. I am contemplating cutting one more off to get it closer to where it was when I got it.
akavinn1
Post by akavinn1 »
wow love that color !!! do u know the color code it looks like positano yellow thats the color i want to make the green 69 i just got
Curly
Your car is a: 1968 AC Coupe and a 1976 CS1 Spider
Post by Curly »
Kings Springs - Catalogue Numbers: Front KFFL-60, Rear KFRL-61(rears are a progressive rate spring)
http://www.kingsprings.com.au/catalogue ... alogue.pdf
Wheels are 15x7 with 195/50/15 tyres.
fiathead
Post by fiathead »
akavinn1 wrote:wow love that color !!! do u know the color code it looks like positano yellow thats the color i want to make the green 69 i just got
It is Positano Yellow. I liked the color enough that when I restored my 88 BMW 325is, I painted it the same color. It's not something you see all too often now days.
BTW, congrats on the '69 Spider. I am a fan of the early AS series Spiders. I've owned a '77 and '76 and the build quality of the '69 seems to be a notch above my other Spiders. Little things like the real wood dash, engine lighting and enameled badges stand out. Plus, they seem a bit more rust resistent than the later cars, but that might just be the luck of the draw for my car.
Tim
fiathead
Post by fiathead »
Curly wrote:Kings Springs - Catalogue Numbers: Front KFFL-60, Rear KFRL-61(rears are a progressive rate spring)
That's a really nice looking Spider.
Tim
akavinn1
Post by akavinn1 »
It's amazing how much better they look lower
jfrawley
Post by jfrawley »
With regards to the question of how the ride is...a little harder. However, it does seem to corner better. The turbo wheels are 14's with Falken 912's at 195/60/14.
JF
John Frawley
Frederick, MD
1982 Spider
Redline
Post by Redline »
Not sure if it applies to Spiders, but this is an interesting read on lowering, control arm angles, roll centers and the effect on handling of the Coupe:
http://turbo124.com/forum/viewtopic.php?f=3&t=6855
http://www.124bc.com
divace73
Post by divace73 »
Too Low
Just about right??
What ever you do, don't go too low, you will cause all sorts of issues and really upset the handeling. The A arms from the front view need to be parralell to the ground as a minimum, the T124 write up on suspension is worth the read.
I have changed the stub axles on my car as well, so that does change the stance.
Cheers David
see my >>You tube channel<<
divace73
Post by divace73 »
Tim
Don't know if you have noticed it is a once piece bumper, I reckon it look great, that is what I want, but I have spoken to Curly and it was quite a challenge to get that made.
Cheers David
Martin124
Post by Martin124 »
I certainly did notice that one piece bumper and was about to ask the question when I noticed your post. I'm not sure if I'm put off yet!
Curly, do you have a photo of the front bumper? (scrap that question... I just found your photo gallery. Sorry, I'm still learning :roll: )
