ECU wires...where do they go??
- ga.spyder
Yeah,I know...in the ECU I have been having issues,and a friend(Thanks John) sent me a ECU to try ansd see if it is the issue.I pulled out mine and there are 2 white wires that I cant figure where they go.They are coming out of the ECU harness and have #12 and #6 stamped on them.They have female spade connectors on the end.They dont appear to go into the double relays as the wires for the relays come out of a different harness..I dont see any empty spades.Possible they arent used?? I didnt see them come loose,so I dont have a clue!
Craig Nelson
Fling It Around Turns !
Re: ECU wires...where do they go??
On mine they're plugged together. Mine has a male and a female connector though, looks like you'll have to make a little pigtail with tow male ends.
These are the only two wires that come out of the bundle, so they must be the same ones, I'm thinking. How you ended up with two female ends on yours is a puzzle.
Ron
Ron
- ga.spyder
Females seem to gravitate towards me Thanks Ron.I may be wrong on the male/female as I didnt try to hook them together.As long as I know they are attached together,I will do that and swap ECUs.I dont know if you have been following the loooooong process of this whole deal.I found a lot of crap in the filter.I think it has gotten to the injectors.If the ECU swap doesnt fix it(not very confident),I am headed back to the injectors/tank.Thanks buddy.
Craig Nelson
