You make a lot of sense Brad. The way I (try to) think, is to buy the best you can and (for the most part) why wait until something fails. It'll be more cost effective in the long run. How much is it worth to not get stuck somewhere?
That said, I need to put my money where my mouth is.
I've been driving the Spider for the last 3-4 days now. She starts right up, idles fine, and I'm not getting any of that power loss issue, so I'm happy. But she does smell like she may be running a little rich, doesn't feel as peppy (technical term) as I think she could be, and when I'm taking her up into the 2.5-4 rpm range on the road I'm experiencing what feels like a slight power wave. Could it possibly be somewhat related to the drivetrain at all (bearings need to be repacked, transmission bearing making a little noise, ball joints and suspension rubber need replacing, etc.)?
Regardless, she could stand a tune-up and I'm obviously gearing up to do it soon using Brad's "Bosch L-Jetronic Fuel Injection Guide, FIAT Fuel Injected Engines " First Edition - July 2004". Is this the best guide, or should I be using the "Engine Maintenance and Modification" (2007)? The 2004 guide appears to be more comprehensive with regard to FIs.
Actually Brad, although I don't mind the stock look, I do like a little bit of color in the engine compartment.
Giulio
