Injectors cleaning
henry
Your car is a: Pininfarina 1983
Injectors cleaning
Post by henry »
Hello everyone!
I would like to know if there's a good product on the market to clean injectors. Thank You.
4uall
Re: Injectors cleaning
Post by 4uall »
I have used both Sea Foam and this
Lucas F.I. Cleaner by itzebtze, on Flickr
with good results and noticeable improvement
Or try one of these guys: I used OK Injectors with great results.
FUEL INJECTOR CLEANING:
http://WWW.OKINJECTORS.COM
http://www.witchhunter.com
majicwrench
Post by majicwrench »
NAPA makes a good product called Cleen.
Personally Sea Foam is snake oil.
The Lucas stuff is probably good.
Personally, again, I dislike putting anything but fuel in my fuel tank.
Do you know your inj are plugging?
Keith
4uall
Post by 4uall »
majicwrench wrote:NAPA makes a good product called Cleen.
Keith
YOU SHUT YOUR MOUTH ABOUT MY PRECIOUS SEA FOAM! :twisted:
:wink: :mrgreen:
anyone know of a good place in Ottawa or Ontario?
majicwrench
Had a salesman come into my shop 20 years ago (maybe more, jeesh) and try to sell me some. Improves gas mileage, decreases oil consumption, increases horsepower, cleans carb ( 20 years ago, remember?) removes moisture and rust from fuel system. Put it in your tank, put it in your crankcase, put it in your trans, it is good for everything. Put it in before storing vehicle for long time. Put it in when starting vehicle after long storage. Put in cylinders with plugs out to clean carbon. Put three or four cans into every customers car!! How many cases did I want to buy????
Sea Foam. THe answer to everything. And what a name.
Keith
