Dead cylinder? I feel sick!
ga.spyder
Re: Dead cylinder? I feel sick!
Post by ga.spyder »
Thats ok....the reason these forums work is guys like that. Mr.Azruss...I'm gettin' there :lol: .All kidding aside,I didnt want to go tearing into every system in the car w/o knowing the problem.I felt I have sytematically eliminated everything except the injector.All signs pointed to ignition or compression related.I am not a ace mechanic,so I kinda' have to sneak up on it!
ps...those compression numbers look pretty good for a 80K car?
Craig Nelson
Fling It Around Turns !
rlux4
Post by rlux4 »
Those numbers are just fine. Last time I checked mine it was in that neighborhood and it runs great. Got spark, got compression, timing is no doubt good, you're looking at a stuck injector ole' buddy. It's getting pulse signal, right?
If you want to get it cleaned quicker than sending it out do a Google search on DIY injector cleaning. There's some pretty ingenious guys out there.
Ron
Ron Luxmore
rlux2n2@gmail.com
I would think the electrical coil in the injector failed. It's very rare for the injector to get clogged while running
ga.spyder
Post by ga.spyder »
I believe it is down to injector 4.I do have pulse signal.Listening with the stethescope ,it does sound a little different than the other 3.Did a ohms test and the resitance is the same across the board.
It was odd they way the cylinder just kicked out,Mark.I am going to try to pull the #4 injector w/o removing the whole rail.Looks like a tough squeeze,but I think it can be done? I am leaving for the track on Thursday morning,so time to work on it is short.Was going to take it to FUN,but that may not happen.
Craig Nelson
Gunsmith
Post by Gunsmith »
Since you don't have another injector you could switch it with another cylinder and see if the problem follows?
ga.spyder
Post by ga.spyder »
Gunsmith,I would do that but they are such a PITA to get out.I am going to visually check the #4 and if it looks bad,buy another injector.I have everything to where I can actually see it spray.If I have to take the whole rail off,then I cant test them.Catch22.The #1 looks pretty easy to get at,so I may try that with that one.
Craig Nelson
