High pressure fuel line
eman2112
Post by eman2112 »
I have been searching in vain for a high pressure fuel line that goes from the hard line to the injector rail. Does anyone know where to get one?
Divers
Re: High pressure fuel line
Post by Divers »
Napa has it or go with 5/16 and most of the chain stores carry it.
eman2112
Post by eman2112 »
It appears to have fittings attached on each end. A one piece design or am I mistaken? This car sat up since 92 and the fittings are corroded so hard to tell. I don't want to break the rail.
azruss
Post by azruss »
the hose connectors are barbed with a retainer cap. removing the old hose usually means cutting the hose off with a razor knife. be careful not to scar the barb and produce a leak path. Any hose supply house has solvent proof 150 psi hose. just dont tell them it is for gas line.
