Crank pulley replacement
dmwhiteoak
Re: Crank pulley replacement
Post by dmwhiteoak »
Both of my manuals stated 180 ish, When I get home in the morning I will double check. I torqued mine to 180ish with no problem. This is the big nut that holds crank pulley and timing gear in place. 1 1/2" socket is what I used.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
JConnerly
Post by JConnerly »
I would agree with 181 ft lbs. Just changed my timing belt today and checked two different manuals for the specs.
psg
Post by psg »
Yes it is the pulley that runs the alternator etc and that is the size of the nut... Okay and thanks for info. psg
maytag
Post by maytag »
My Haynes manual states 181 ft/lbs.
Not 80.
and mine is a 38mm. (which is something like 1.49" :wink: )
psg
Post by psg »
I have rechecked my manual so tell me where you are looking as I must be referencing the wrong part or just a completely different addition... I am used to being lost but I like to know how it happened. thanks. psg
