Fuel Filter replacement
johnssi
Post by johnssi »
The Fiat manual says that when changing the fuel filter on my 81 spider to relieve the pressure by using a hand vacuum pump before attempting the replacement. Can anybody tell me if that is really necessary to do, or can I just crack one of the hose clamps at the filter and let the pressure bleed off. I don't have a vacuum pump and at $60 at the auto parts place, I don't really want to buy one if it's not necessary. Thanks.
4uall
Re: Fuel Filter replacement
Post by 4uall »
when I did mine I simply disconnected the neg terminal & pulled the fuel pump fuse, then removed the filter with a catch basin underneath. Not sure how glamorous that was however, it did the job and no issues yet :shock:
this was the reason why http://wwwe.fiatspider.com/f08/viewtopi ... =9&t=17531
bradartigue
Post by bradartigue »
I've never bothered. Gas leaks out no matter what you do, be clean, be careful, and you won't have problems. Dead cold engine, no smoking, that sort of thing. You do want to clamp the line or have an empty tank (or very, very fast hands!)
Fiat88
Post by Fiat88 »
I don't have a FI spider but can't you just pull the fuel pump fuse or relay and then crank the engine over to relieve the pressure in the lines. This is what I did on my dads 98 VW golf to change the fuel filter.
johnssi
Post by johnssi »
Thank you for all the replies. I'm going to change it out today and will post when I've got it done. Thanks again.
John
