No idle after back fire - 34DMS(A) Weber
pressonregardless
Your car is a: 1974 Spider
Post by pressonregardless »
Looking for any information on cleaning / rebuilding a Weber 34 DSMA on my 1974 Spider 1756.
It has run very smoothly on several trips over the summer and I was running around town on some errands and all was fine. The engine sat in the drive for about 1 hour in 95' temps and I went to start things to put it away for the day. As I cranked, the engine (what I call backfired, or burped in the carb/air cleaner assy). I cranked again and now I have no idle. I drove around the block and all is fine above 1500 rpm, but can't idle. I pulled all plugs and wires, all clean.
Any thoughts, I believe it is something in the Carburetor circuit since the problem instantly appeared when the engine choked up on starting. Charlie
1974 Spider, 1756cc, points & Carb, 118K California miles
76was124
Patron 2019
Patron 2019
Re: No idle after back fire - 34DMS(A) Weber
Post by 76was124 »
Do you think it could be timing, as you might have jumped a tooth on the timing belt, or are you thinking more like a fuel problem like a vapor lock?
Current 81 Spider 2000
Previous 76 Spider
timinator
Post by timinator »
Could be as simple as a vacuum hose has been blown off by the backfire. It usually is one that you can't easily see. Or maybe a piece of gasket blown out. Just depends on luck or the lack of luck.
