Bosch Fuel Injector screen and seals
76was124
Patron 2019
Patron 2019
Post by 76was124 »
Pulled the fuel rail today as part of the final part of firing up a car that sat for ten years.
Here is the fuel rail and a close up on an injector as they looked when pulled.
i am guessing the double seals missing on two injectors are stuck in the engine ports, but does the FI tip look right? i was expecting a visible screen?
Car consitently starts and idles smooth off the cold start injector, but consistently stalled after 2 3 seconds which is when i figure the FIs should take over. So following advice on another post I removed the injectors to have them cleaned and flow tested. i just want to be sure i didn't leave clogged screens in the engine ports.
Current 81 Spider 2000
Previous 76 Spider
Re: Bosch Fuel Injector screen and seals
the screens are in the injector inlet. If it was on the nozzle, the spray pattern would be disrupted
76was124
Patron 2019
Patron 2019
Post by 76was124 »
Thanks Mark, that makes more sense as I wondered how that would work with the spray pattern,
Previous 76 Spider
