oxygen sensor
joelittel
oxygen sensor
Post by joelittel »
My O2 sensor is stuck and I can't get it out. Is there a trick to this or a tool that works best?
bradartigue
Re: oxygen sensor
Post by bradartigue »
joelittel wrote:My O2 sensor is stuck and I can't get it out. Is there a trick to this or a tool that works best?
There is actually a wrench made to fit it, but when mine have been stuck I have cut the top off and used a socket on it, or just used a long socket.
You can also soak it in pblaster it may help, or use a torch to heat up the pipe around it, causing the threaded part to expand slightly.
