steering box oil
agv
steering box oil
Post by agv »
I want to check the oil level on my '82 but I cant find a tool to remove the square bolt and I dont want to strip it... any suggestions?
fiat218
Re: steering box oil
Post by fiat218 »
agv wrote:I want to check the oil level on my '82 but I cant find a tool to remove the square bolt and I dont want to strip it... any suggestions?
Square bolt in the center? Mine was 10mm, I believe
agv
Post by agv »
yes I believe it is a 10mm male. where can I get a tool for this? I see lots of square drives for female oil drain plugs but not male...
aj81spider
Post by aj81spider »
My engine was out when I did it, so I don't know if it there's enough room with the engine in, but I just used an adjustable wrench and closed it on two sides of the square.
A.J.
2006 Corvette
fiat218
Post by fiat218 »
agv wrote:yes I believe it is a 10mm male. where can I get a tool for this? I see lots of square drives for female oil drain plugs but not male...
just a socket is what i used ( 3/8 drive
agv
Post by agv »
will attempt both tools..thanks....hope it doesnt round off
redcars
Post by redcars »
You can buy 8 pt sockets made for four sided fasteners. This is what I would use if it dosen't turn without worry of rounding with the other tools.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
