Power
fiat218
Power
Post by fiat218 »
I need more power,zip,in my 80 2000,I did remove al smog and swap out the carb, what else can I do
narfire
Re: Power
Post by narfire »
1800 head, cams, adjustable cam wheels . You have the 4-2-1 exhaust?
Spend some $$$$-- rebore for oversized HC pistons, balanced, no power gain but shave some weight off the flywheel?
No end to what you can do or spend, but ask yourself budget and what do you want the end result to be, still nicely drivable in traffic, (not too lumpy) but has a bit more poop in the midrange..
I found the biggest difference in my FI was head work, cams and adjustable wheels and degreed in properly.
Blew by a TR-6 on the local road to town yesterday :D
Chris
fiat218
Re: Power
Post by fiat218 »
narfire wrote:1800 head, cams, adjustable cam wheels . You have the 4-2-1 exhaust?
Chris
i was not thinking of going extreme
fiat218
Re: Power
Post by fiat218 »
Chris
i have a 1608,in which i plan on going the max on
narfire
Re: Power
Post by narfire »
[I need more power,zip,in my 80 2000,I did remove al smog and swap out the carb, what else can I do[/quote]
I' m reading you have two engines/cars
quote="fiat218"]i have a 1608,in which i plan on going the max on[/quote][quote="fiat218"]
Regardless , get an idea as to what you want from the car. I'd recomend sourcing a 1800 head for the 2L and have it surfaced, valves and guides done. A compression increase there. With your new carb you have a single plane intake right.
If you don't have it, a 4-2-1 exhaust as well. Basically all bolt on improvements without tearing the engine down and getting into expensive after market parts. I'm sure you'll be seeing/ feeling an improvement.
Have fun with the 1608...
