top door rubber
fiat218
top door rubber
Post by fiat218 »
how do u get that in, door rubber is thicker then the orginal, or it was just crimped in fter it was installed, anyways i spread my chrome peice a tad to get it in then i took a screw driver and hammer to crimp it back again, there has to be a better way
any one ever change theses.
manoa matt
Re: top door rubber
Post by manoa matt »
If your stretch the rubber window scraper it will thin out enough to slip into the stainless trim piece. I would not use a lubricant as the rubber will just slip out again.
fiat218
Re: top door rubber
Post by fiat218 »
manoa matt wrote:If your stretch the rubber window scraper it will thin out enough to slip into the stainless trim piece. I would not use a lubricant as the rubber will just slip out again.
I got them in, I basically open up the ridge a tad and put it in, back on the car then took a flat screw driver and hit it with a hammer to put the crease tighter again, seems to work
BEEK
Your car is a: 1975 Spider
Re: top door rubber
Post by BEEK »
also a touch of yellow weatherstrip adheasive in the bottom of the channel works well too, just not too much
75 spider
son has 78 spider
fiat218
Re: top door rubber
Post by fiat218 »
BEEK wrote:also a touch of yellow weatherstrip adheasive in the bottom of the channel works well too, just not too much
Ok thanks
