Speedo hookup leaking
JammerX19
Post by JammerX19 »
How is this fixed? Is there a gasket? Mine is soaking wet.
Jody Farr
'74 124 Spider
'12 Fiat 500 Prima Edizione #13
TX82FIAT
Re: Speedo hookup leaking
Post by TX82FIAT »
JammerX19, do you mean where the speedo cable hoks to the transmission. As far as I know that side of the speedo cable is a screq on and it is hard for big hand people to get up there. Two things. One, there is a little rubber gasket that goes over cable. Got one at Auto Ricambi. Two, use a set of extended long nose pliers of some other specialized thin wrench to carefully tighten the cable on the trans.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
